How to view the history of vm migrations | Nutanix Community
How can I view the history of vm migrations. We had business impakt on an application, that apparently is so sensitive that a migration between nodes in the same cluster caused a split brain situation according to the supplier. However I want to see if that particular vm was migrated in that timeframe the supplier indicated.
Can someone provide me this troubleshoot procedure?
  • March 24, 2025
How were the VMs migrated? Did you use Move.
You can see it in Prism Central. Go to: Infrastructure → Activity → Audits → And filter on “Operation Type = Migrate”
  • March 31, 2025
Hi Jeroen,
Thx for the response, I wanted to dive deeper then the info available in PC. In the meanwhile I found the documentation how to see every little step the migration executes.
