Is Network Controller supported on Community Editon 2.1? | Nutanix Community
Hello, just finished installing a new CE 2.1 cluster to experiment a bit, and a new Prism Central. Trying to enable Network Controller, but it says my cluster is not supported. Is this not a feature supported by CE?
Or would I have to use a different Prism Central version?
Upgrade the CE 2.1 cluster to the latest versions. (Run LCM in Prism Element).
And to answer your question, yes you can test with FNS in CE.
  • 7 replies
  • March 19, 2025
Ah thank you very much, i’ll give it a update and see if I can’t get it to work.
  • 7 replies
  • March 19, 2025
Hmm, ran the LCM update and got up to 6.10.1, and can’t update further because of this ‘error’
And when I check FNS, it still says it’s still not supported
