Community Edition, can't reach CVM's when trying to segment backplane LAN | Nutanix Community
Hi! I’m trying to segment, the backplane LAN on an already existing cluster, it passes the validation, but then I get this error when it gets to about 45% Anyone know what i’m doing wrong?
I’m following this documentation Link
My CVM’s use 10.10.10.11,21,31
And AHV use 10.10.10.10,20,30
Trying to get the backplane to use a 10.10.11.0/24 on a different physical switch. All ports are VLAN tagged with VLAN11 just like the
This is the error I get
When looking in the Foundation logs, they fail to ping eachother, but I don’t know what the issue there could be, they are using the correct IP’s and the interfaces are up on both sides.
What vlan in the normal subnet using? And what is the subnetmask of the current ahv/cvm setup.?
  • 7 replies
  • March 18, 2025
The normal vlan is 10, and they’re running on a /24 subnet
  • 7 replies
  • March 18, 2025
Tried to visualize it quickly to maybe help explain it.
Did you create a new virtual switch with the correct interfaces which are connected to switch2?
  • 7 replies
  • March 18, 2025
Yes, created a vs1 switch, which has it’s own interfaces, that only connect to switch2
  • 7 replies
  • March 19, 2025
Thanks a lot for your input, ended up just doing a complete reinstallation of the cluster, and then using switch2 as the first switch, and creating VM vlans on switch1.
