Is it possible to change VM UUID | Nutanix Community
  • February 28, 2025
  • 54 views
Hi All,
I wanted to change VM UUID due to some technical reason, could you please help me for the same.
Ratnakar
  • March 8, 2025
Yes we need to edit the VM ID too. Any help?
No that is not possible. What is possible is changing the bios uuid.  (acli vm.update <vm_name> bios_uuid=#######
Can you expain why you want to change the vm uuid? Is it for data protection purposes? Or for backup purposes?
