A client has requested to migrate a Windows Server VM (Domain Controller) installed in a VMWare ESXi cluster to the Nutanix cluster with AHV. I have only migrated Windows and Linux VMs with Nutanix Move, in this case I do not know if it is advisable to do the migration. I have not found any information on this matter. I would appreciate if you could tell me if it is possible to migrate the Domain Controller without any problems or if it is advisable to create a new VM configured as a Domain Controller in Nutanix. If it is possible to do the task with Nutanix Move, how should I do it? Thank you.
Is it possible to migrate a VM (Domain Controller) from ESXi to AHV? Is there a problem? How to do it?
