File server download goes straight to retry | Nutanix Community
jbale1966
When trying to download file server 5.0.0.3 or below the download starts the automatically stops and goes to retry, i click on retry and it goes to resume download,  i click on resume download and starts all over.   I’ve tailed my firewall logs,  it’s not getting blocked at the firewall.  I’ve already done all the upgrades and patches on the system.  Anyone have any ideas?
if you are still facing the same issue, just download the binaries in your computer and upload it to your cluster.
this should sort out your downloading issue.
jbale1966
  • February 18, 2025
where can i get the binaries?  Im just using the community edition.
Jamie Terrell
Do you have access to https://portal.nutanix.com? If so they are located in the Download section. Also have you tried any other version?
as ​@Jamie Terrell mentioned it is in Download folder  . just login to my.nutanix.com and go to download section and then select fileserver.
select your version to download.
