Can a guest VM´s ownership be changed after creation? | Nutanix Community
  • January 10, 2025
  • 152 views
All existing guest VMs created in AHV have admin as the owner except one as in the screenshot, Is there an available way to change that ownership to admin?
Thanks for your answers in advance
Best answer by Jlperezdlp
Thank you, we tried but it asks for a project which does not apply in this case.
I´ll double check though.  Thanks!
BartDonders
  • Trendsetter
  • 48 replies
  • January 14, 2025
It is possible to change the owner of the VM… That is an action in Prism Central on the VM. I am not sure if you can change it to admin, but you can try. ;-)
  • 8 replies
  • January 14, 2025
  • 9 replies
  • January 14, 2025
Hi ​@Jlperezdlp
On “Manage Ownership” pop-up, you can keep “Project” blank and from “User” choose user (e.g. admin). It’ll work !!
@BartDonders your suggested solution works 👍
  • 8 replies
  • January 20, 2025
Just an update: For some reason Prism was not allowing to edit the owner. With the help of support it was solved by running the following command:
nuclei vm.update IFSRVMDPRE01 metadata.owner_reference.uuid=00000000-0000-0000-0000-000000000000
