Deploying NDB solely on a VMware infrastructure without an accompanying Nutanix cluster is not supported?
Best answer by ktelep
Correct, NDB is dependent on technologies within the Nutanix Distributed Storage Fabric, so it must be deployed on Nutanix infrastructure (it can be ESXi or AHV on Nutanix)
