EXPORTING CLUSTER CERTIFICATES | Nutanix Community
  • December 5, 2024
  • 51 views
Hello and thank you.
Can anyone provide command lines or script that I can use to export ssl certificates from Prism Central and Prism Element clusters AOS 6.10 and 6.8.0.1?
  • 1367 replies
  • December 6, 2024
Export not but import can be found here (well an example to use for creating your won script)
https://www.jeroentielen.nl/replace-nutanix-ssl-certificate-with-lets-encrypt-certificate/
