Hi there,
I am trying to install the CE version for testing in my home lab with a MSI cubi 5, I am using an NVMe drive and a SATA SSD for DATA and CVM respectively, and I thought I could use a USB stick for the AHV, however, I get a timeout whenever I try to run the installation even though I increased the timeout in the installer_vm.py, any suggestions?
Thanks!
The USB drive is worn out. Use a new one. 👍🏻
Watch out for the support of NVMe because I thought these weren’t yet supported. What size of usb are you using? Maybe it’s to small I had to switch to a 64GB for the boot stick.
Check this out: https://next.nutanix.com/installation-configuration-23/nutanix-ce-install-with-nvme-drives-43756
