Upgrade CE 2.1 to AOS 6.10 | Nutanix Community
  • November 4, 2024
  • 482 views
I upgraded AOS 6.8.1 to 6.10 but now I have a version incompatible with AHV and it is impossible via LCM to upgrade AHV. In the related KB 15185 there is a workaround but it does not work in my nested environment. Does anyone have a suggestion?
Best answer by JeroenTielen
Read this: https://next.nutanix.com/discussion-forum-14/unable-to-upgrade-ahv-hypervisor-43714
  • 1372 replies
  • November 5, 2024
