upgarde AOS only without upgrading the esxi | Nutanix Community
  • September 19, 2024
  • 0 replies
  • 20 views
Hello Experts,
It is possible to update the cluster to a version of AOS that supports ESXi 6.7 U3. However, we do not have a license for ESXi 7 or 8.
We must upgrade and deploy the PC. The current version is 5.20.3.5.
After reviewing the compatibility matrix on the Nutanix portal, I discovered that this version of AOS 6.5.3.7 is compatible with ESXI 6.7 U2 and U3.
did any one tested that before ?
and i would like to deploy PC,
PS : this cluster has esxi 6.7 u3 as hypervisor
