Create vm from Template using Powershell | Nutanix Community
  • September 9, 2024
  • 173 views
I’m somewhat disappointed in the product, , trying to create a VM from a template using Powershell. Modules are installed and we’re of to a flying start with this:
Import-Module Nutanix.Cli
Import-Module Nutanix.Prism.PS.Cmds -Prefix NTNX
Import-Module Nutanix.Prism.Common -Prefix NTNX
Connect-PrismCentral -Server $PrismServer -Credential $cred -ForcedConnection -AcceptInvalidSSLCerts
After this we’re in strife. Even the simple example below (from https://portal.nutanix.com/page/documents/details?targetId=PS-Cmdlets-AOS-v6_8:cmd-ps-VM-auto-r.html) does not work:
New-VM -Name testvm1 -ClusterName poc-cluster -NumVcpus 1 -MemoryMb 500
Results in this:
Task(s) bf18c5bc-6588-4f49-8914-3ad5da414b27 failed due to Failed to call REST endpoint from Prism Central : cluster not reachable.
The cluster is reachable (on the same subnet), port 9440 is open and responding.
Any ideas?
  • September 13, 2024
Well, we actually had a misconfigured cluster..now it has been fixed so we get the Powershell modules to work and we can create empty virtual machines.
But, here is our current dilemma...we plan on deploying VM’s from a template, and would like to do this similar to what we did in VMware, specifying parameters such as compuer name and IP address (via VMWare’s custom specifications).
How would we go about to
  • Create a VM from a template, say “nutanix_vm_template”
  • Input parameters computer name and IP configuration
Any ideas?
