Centralized Log Locations for Cluster Processes | Nutanix Community
  • August 21, 2024
  • 99 views
Is there a centralized document that discusses where logs should be for specific  processes through the cluster or is it broken down into each applications documentation?
i.e. - I’m installing Prism Central and I want to watch the logging progress for the process that is running.
One way I learn is to watch logs and see what the system is doing to try and understand flows but I can’t seem to figure out where exactly to look.
Best answer by sl.farhanparkar
All the logs are placed in /data/logs folder and broken by services, but the first log file to check always is genesis.out.
The active log files are with .out and historic are zipped/archived in same location
This is part of NSS certification for SRE and not advisable by normal partner or customer as the information is too extensive in the log files.
Note: Not every error in log file is issue.
F>P
sl.farhanparkar
F>P
