Reset AHV Nodes to Factory Settings | Nutanix Community
  • August 19, 2024
  • 210 views
I am doing 4 node AHV cluster decommission. I did all the steps and finally gave cluster destroy and ensure it was destroyed completely. I want to do a factory reset of all the nodes where the hypervisor /CVM configurations like hostname, IP etc will be wiped out. Please let me know the procedure for this. Thanks.
Best answer by aluciani
Best to reach out to Nutanix support.
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • August 21, 2024
