VLAN Trunking and IP Assignment per NIC | Nutanix Community
Hi, If I enable VLAN trunking at VM level, say for example VLAN 100 and VLAN 200. Do I need to assign two different IPs in the same NIC for each VLAN?
Best answer by Scipio
If you set up the NIC as a trunk on the Nutanix side, you have to configure your OS to tag the outgoing packet. Usually, this is done by creating 2 sub interfaces with the proper configuration. If you only need 2 interfaces, you probably should just create 2 NIC's in access mode, it will be much easier. Trunk mode is useful mainly for virtual network appliances like firewall.
  • 1393 replies
  • August 1, 2024
This has nothing to do with nutanix. Refer to the documentation of the operating system how to configure multiple vlans to 1 nic. I assume you have to add two interfaces tot the vm. But I dont know for sure.
  • 6 replies
  • August 2, 2024
