Hello everyone,
I am currently experiencing an issue while installing a Nutanix cluster on two Lenovo ThinkAgile HX630 V3 CN nodes, with a witness virtual machine. Below are the detailed system versions and the error messages encountered.
AOS and AHV Versions:
AOS:
- 192-168-75-10: 6.8
- J901TNBT (ThinkAgile HX630 V3 CN): 6.5.3
- J901TNBV (ThinkAgile HX630 V3 CN): 6.5.3
AHV:
- 192-168-75-10: ?
- J901TNBT (ThinkAgile HX630 V3 CN): AHV el7.nutanix.20220304.385
- J901TNBV (ThinkAgile HX630 V3 CN): AHV el7.nutanix.20220304.385
The installation fails at the "ImagingStepProvisionNetwork" step with an error message indicating a "Timeout (240s) in waiting for events ['provision_remote']". This seems to cause a cascade of failures in subsequent installation steps, preventing the process from completing.
I have verified the current IP addresses and potential conflicts via arp-scan, but this has not resolved the issue.
Has anyone encountered this type of issue or have any suggestions on how to resolve it ?
Thank you in advance for your help.
Error Message:
2024-07-14 06:52:43,838Z DEBUG Setting state of <ImagingStepProvisionNetwork(<NodeConfig(192.168.75.109) @5490>) @5510> from PENDING to RUNNING
2024-07-14 06:52:43,839Z INFO Running <ImagingStepProvisionNetwork(<NodeConfig(192.168.75.109) @5490>) @5510>
2024-07-14 06:52:46,535Z INFO rpc method <unbound method NodeManager.get_ip>, target fe80::526b:8dff:fede:4001%eth0
2024-07-14 06:52:46,535Z INFO cherrypy {}
2024-07-14 06:52:48,644Z INFO Starting arp-scan to check for conflicts
2024-07-14 06:53:00,864Z INFO Current IP usage is ['192.168.75.101', '192.168.75.102', '192.168.75.103', '192.168.75.104', '192.168.75.105', '192.168.75.106', '192.168.75.107', '192.168.75.108', '192.168.75.109']
2024-07-14 06:53:02,462Z INFO IPs not reported by arp-scan but in user input: ['192.168.75.104', '192.168.75.105', '192.168.75.106', '192.168.75.107', '192.168.75.101', '192.168.75.102', '192.168.75.103', '192.168.75.108', '192.168.75.109']
2024-07-14 06:53:29,680Z INFO ARP scan completed successfully
2024-07-14 06:53:29,680Z INFO Waiting for remote nodes to provision network
2024-07-14 06:57:29,701Z ERROR Exception in running <ImagingStepProvisionNetwork(<NodeConfig(192.168.75.109) @5490>) @5510>
File "foundation/imaging_step.py", line 161, in _run
self.run()
File "foundation/imaging_step_provision_network.py", line 237, in run
timeout=provision_remote_nodes_wait_time)
File "foundation/config_manager.py", line 352, in wait_for_event
"Timeout (%ss) in waiting for events %s" % (timeout, event_names))
EventTimeoutException: Timeout (240s) in waiting for events ['provision_remote']
2024-07-14 06:57:29,702Z DEBUG Setting state of <ImagingStepProvisionNetwork(<NodeConfig(192.168.75.109) @5490>) @5510> from RUNNING to FAILED
2024-07-14 06:57:29,703Z DEBUG Setting state of <ImagingStepValidation(<NodeConfig(192.168.75.109) @5490>) @56d0> from PENDING to NR
2024-07-14 06:57:29,703Z WARNING Skipping <ImagingStepValidation(<NodeConfig(192.168.75.109) @5490>) @56d0> because dependencies not met, failed tasks: [<ImagingStepProvisionNetwork(<NodeConfig(192.168.75.109) @5490>) @5510>]
2024-07-14 06:57:29,704Z DEBUG Setting state of <ImagingStepHandoffPrepare(<NodeConfig(192.168.75.109) @5490>) @5ed0> from PENDING to NR
2024-07-14 06:57:29,704Z WARNING Skipping <ImagingStepHandoffPrepare(<NodeConfig(192.168.75.109) @5490>) @5ed0> because dependencies not met
2024-07-14 06:57:29,705Z DEBUG Setting state of <GetNosVersion(<NodeConfig(192.168.75.109) @5490>) @ff50> from PENDING to NR
2024-07-14 06:57:29,705Z WARNING Skipping <GetNosVersion(<NodeConfig(192.168.75.109) @5490>) @ff50> because dependencies not met
2024-07-14 06:57:29,706Z DEBUG Setting state of <ImagingStepTypeDetection(<NodeConfig(192.168.75.109) @5490>) @5590> from PENDING to NR
2024-07-14 06:57:29,706Z WARNING Skipping <ImagingStepTypeDetection(<NodeConfig(192.168.75.109) @5490>) @5590> because dependencies not met
2024-07-14 06:57:29,707Z DEBUG Setting state of <ImagingStepInitCVM(<NodeConfig(192.168.75.109) @5490>) @5350> from PENDING to NR
2024-07-14 06:57:29,707Z WARNING Skipping <ImagingStepInitCVM(<NodeConfig(192.168.75.109) @5490>) @5350> because dependencies not met
2024-07-14 06:57:29,707Z DEBUG Setting state of <ImagingStepRAIDCheckPhoenix(<NodeConfig(192.168.75.109) @5490>) @0310> from PENDING to NR
2024-07-14 06:57:29,708Z WARNING Skipping <ImagingStepRAIDCheckPhoenix(<NodeConfig(192.168.75.109) @5490>) @0310> because dependencies not met
2024-07-14 06:57:29,708Z DEBUG Setting state of <ImagingStepPreInstall(<NodeConfig(192.168.75.109) @5490>) @0550> from PENDING to NR
2024-07-14 06:57:29,709Z WARNING Skipping <ImagingStepPreInstall(<NodeConfig(192.168.75.109) @5490>) @0550> because dependencies not met
2024-07-14 06:57:29,709Z DEBUG Setting state of <ImagingStepPhoenix(<NodeConfig(192.168.75.109) @5490>) @e550> from PENDING to NR
2024-07-14 06:57:29,709Z WARNING Skipping <ImagingStepPhoenix(<NodeConfig(192.168.75.109) @5490>) @e550> because dependencies not met
2024-07-14 06:57:29,710Z DEBUG Setting state of <InstallHypervisorKVM(<NodeConfig(192.168.75.109) @5490>) @ee10> from PENDING to NR
2024-07-14 06:57:29,710Z WARNING Skipping <InstallHypervisorKVM(<NodeConfig(192.168.75.109) @5490>) @ee10> because dependencies not met
2024-07-14 06:57:29,711Z DEBUG Setting state of <ImagingStepHandoff(<NodeConfig(192.168.75.109) @5490>) @ee90> from PENDING to NR
2024-07-14 06:57:29,711Z WARNING Skipping <ImagingStepHandoff(<NodeConfig(192.168.75.109) @5490>) @ee90> because dependencies not met
