identify physical port nx-3235-g9 | Nutanix Community
  • July 9, 2024
  • 169 views
How to identify which NIC 1 NIC 2 etc or eth0 eth1 eth3 and eth4 on physical side. in my case, i want to configure the network active-backup and how to identify which port is eth1 or eth2 either on physical view or prism element dashboard
thank you
Peter Seidl
Hi @Ahmad Barizie,
maybe you can try checking the Hardware Documentation in the Nutanix Portal:
Platform ANY - Network Interface Card Replacement (AHV) (nutanix.com)
Here you should be able to check which NIC is in which slot.
Also you can check in Prism Element in the “Network”-View in the menu.
There you can click the Node-Name and get an overview of which NIC is connected to your vSwitch. With the LLDP Info you should also see to which switchport your nutanix NICs are connected.
I hope this helps.
