identify physical port | Nutanix Community
How to identify which NIC 1 NIC 2 etc or eth0 eth1 eth3 and eth4 on physical side. in my case, i want to configure the network active-backup and how to identify which port is eth1 or eth2 either on physical view or prism element dashboard
thank you
Best answer by JeroenTielen
I assume you have not created the cluster yet? Run the crashcart utility and you can see the eth names and their link state and their mac addresses.
More info here: The Nutanix Network Crashcart a hidden gem - Jeroen Tielen
  • 1372 replies
  • July 9, 2024
  • July 10, 2024
ethtool -p(--identify) devname
// ethtool -p eth0
I think it might be useful to you.
  • 12 replies
  • July 11, 2024
Thank you all for the best answer
