Nutanix CE New Single Cluster Creation Errors | Nutanix Community
I have just completed the initial deployment for the Nutanix-CE on a Single Node.
Upon running cluster status command i see several services are down. Attached is a log, can anyone point me in the right direction.
nutanix@NTNX-6c98f74b-A-CVM:10.0.250.91:~$ cluster -s 10.0.250.91 --redundancy_factor=1 create
2024-05-30 03:12:58,346Z INFO MainThread cluster:2943 Executing action create on SVMs 10.0.250.91
2024-05-30 03:13:01,416Z INFO MainThread cluster:1007 Discovered node:
ip: 10.0.250.91
        rackable_unit_serial: 6c98f74b
        node_position: A
        node_uuid: 56b8d0d2-5fb8-4f69-9630-3b2c8a3938b2
2024-05-30 03:13:01,416Z INFO MainThread cluster:1025 Cluster is on arch x86_64
2024-05-30 03:13:01,417Z INFO MainThread genesis_utils.py:8077 Maximum node limit corresponding to the hypervisors on the cluster (set([u'kvm'])) : 32
2024-05-30 03:13:01,424Z INFO MainThread genesis_rack_utils.py:50 Rack not configured on node (svm_ip: 10.0.250.91)
2024-05-30 03:13:01,425Z INFO MainThread cluster:1221 Setting domain fault tolerance level to kDisk
2024-05-30 03:13:15,966Z INFO MainThread cluster:1332 iptables configured on SVM 10.0.250.91
2024-05-30 03:13:15,973Z INFO MainThread cluster:1351 Creating certificates
2024-05-30 03:13:19,589Z INFO MainThread cluster:1368 Setting the cluster functions on SVM node 10.0.250.91
2024-05-30 03:13:19,591Z INFO MainThread cluster:1373 Configuring Zeus mapping ({u'10.0.250.91': 1}) on SVM node 10.0.250.91
2024-05-30 03:13:23,227Z INFO MainThread cluster:1396 Creating cluster with SVMs: 10.0.250.91
2024-05-30 03:13:23,539Z INFO MainThread cluster:1407 Will seed prism with password hash $6$Ej223/QPGNcQB$Pp1plB7W2.hxswYWiywajdfgS0YYBCyxa/fK7eDoy8FzaDpZFjdJZLprFpCY8O.Y0dpdBNP.XQWT12WvRWCAQ/
2024-05-30 03:14:22,662Z INFO MainThread cluster:1425 Zeus is not ready yet, trying again in 5 seconds
2024-05-30 03:15:23,094Z INFO MainThread cluster:1425 Zeus is not ready yet, trying again in 5 seconds
2024-05-30 03:15:45,723Z INFO MainThread cluster:1444 Waiting for services to start
Waiting on 10.0.250.91 (Up, ZeusLeader) to start:  SysStatCollector IkatProxy IkatControlPlane SSLTerminator SecureFileSync Medusa DynamicRingChanger Pithos InsightsDB Athena Mercury Mantle Stargate InsightsDataTransfer Ergon GoErgon Cerebro Chronos Curator Prism Hera CIM AlertManager Arithmos Catalog Acropolis Uhura NutanixGuestTools MinervaCVM ClusterConfig APLOSEngine APLOS PlacementSolver Lazan Polaris Delphi Security Flow Anduril XTrim ClusterHealth
2024-05-30 03:18:00,505Z INFO MainThread cluster:1976 Waiting for response from 10.0.250.91
2024-05-30 03:18:15,509Z INFO MainThread cluster:1976 Waiting for response from 10.0.250.91
2024-05-30 03:18:30,511Z INFO MainThread cluster:1976 Waiting for response from 10.0.250.91
2024-05-30 03:18:45,513Z INFO MainThread cluster:1976 Waiting for response from 10.0.250.91
Waiting on 10.0.250.91 (Down) to start:
2024-05-30 03:19:00,642Z INFO MainThread cluster:1976 Waiting for response from 10.0.250.91
The state of the cluster: Unknown
Lockdown mode: Disabled
        CVM: 10.0.250.91 Down
2024-05-30 03:19:09,684Z INFO MainThread cluster:1450 Running CE cluster post-create script
2024-05-30 03:19:09,691Z INFO MainThread cluster:3104 Success!
nutanix@NTNX-6c98f74b-A-CVM:10.0.250.91:~$ genesis status
2024-05-30 03:28:31.025780: Services running on this node:
  foundation: []
  genesis: [2863, 3873, 3897, 3898, 5312, 5314, 5315, 5317]
  scavenger: [30986, 31175, 31176, 31177]
  sys_stat_collector: [5850, 5916, 5917, 5918]
  xmount: [30983, 31148, 31149, 31188]
  zookeeper: [26072, 26120, 26121, 26122, 26132, 26149]
nutanix@NTNX-6c98f74b-A-CVM:10.0.250.91:~$ cluster status
2024-05-30 03:30:19,810Z INFO MainThread zookeeper_session.py:191 cluster is attempting to connect to Zookeeper
2024-05-30 03:30:19,853Z INFO Dummy-1 zookeeper_session.py:625 ZK session establishment complete, sessionId=0x18fc77eda60009b, negotiated timeout=20 secs
2024-05-30 03:30:19,882Z INFO MainThread cluster:2943 Executing action status on SVMs 10.0.250.91
The state of the cluster: start
        CVM: 10.0.250.91 Up, ZeusLeader
                                Zeus   UP       [26072, 26120, 26121, 26122, 26132, 26149]
                           Scavenger   UP       [30986, 31175, 31176, 31177]
                              Xmount   UP       [30983, 31148, 31149, 31188]
                    SysStatCollector   UP       [5850, 5916, 5917, 5918]
                           IkatProxy   UP       [6480, 6532, 6533, 6534]
                    IkatControlPlane   UP       [6873, 6987, 6988, 6989]
                       SSLTerminator   UP       [6932, 7060, 7061]
                      SecureFileSync   UP       [6994, 7110, 7111, 7115]
                              Medusa   UP       [7498, 7600, 7601, 7610, 7931]
                  DynamicRingChanger   UP       [8435, 8506, 8507, 8516]
                              Pithos   UP       [8510, 8614, 8615, 8624]
                          InsightsDB   UP       [8539, 8669, 8670, 8689]
                              Athena   UP       [8620, 8754, 8755, 8756]
                             Mercury   UP       [8712, 9090, 9091, 9099]
                              Mantle   UP       [9008, 9225, 9226, 9232]
                            Stargate DOWN       []
                InsightsDataTransfer DOWN       []
                               Ergon DOWN       []
                             GoErgon DOWN       []
                             Cerebro DOWN       []
                             Chronos DOWN       []
                             Curator DOWN       []
                               Prism DOWN       []
                                Hera DOWN       []
                                 CIM DOWN       []
                        AlertManager DOWN       []
                            Arithmos DOWN       []
                             Catalog DOWN       []
                           Acropolis DOWN       []
                               Uhura DOWN       []
                   NutanixGuestTools DOWN       []
                          MinervaCVM DOWN       []
                       ClusterConfig DOWN       []
                         APLOSEngine DOWN       []
                               APLOS DOWN       []
                     PlacementSolver DOWN       []
                               Lazan DOWN       []
                             Polaris DOWN       []
                              Delphi DOWN       []
                            Security DOWN       []
                                Flow DOWN       []
                             Anduril DOWN       []
                               XTrim DOWN       []
                       ClusterHealth DOWN       []
2024-05-30 03:30:25,612Z INFO MainThread cluster:3104 Success!
2024-05-30 03:35:46,683Z INFO MainThread zookeeper_session.py:191 cluster is attempting to connect to Zookeeper
2024-05-30 03:35:46,711Z INFO Dummy-1 zookeeper_session.py:625 ZK session establishment complete, sessionId=0x18fc77eda600140, negotiated timeout=20 secs
2024-05-30 03:35:46,726Z INFO MainThread cluster:2943 Executing action status on SVMs 10.0.250.91
2024-05-30 03:35:46,978Z INFO MainThread cluster:3104 Success!
Best answer by dwahome
I have just checked after a few hours.
The host has 32GB or RAM
All services are running, it seems the services take quite a long time to start!
2024-05-30 07:17:04,158Z INFO MainThread zookeeper_session.py:191 cluster is attempting to connect to Zookeeper
2024-05-30 07:17:04,194Z INFO Dummy-1 zookeeper_session.py:625 ZK session establishment complete, sessionId=0x18fc77eda600b21, negotiated timeout=20 secs
2024-05-30 07:17:04,229Z INFO MainThread cluster:2943 Executing action status on SVMs 10.0.250.91
                          InsightsDB   UP       [8539, 8669, 8670, 12789]
                             Mercury   UP       [9705, 9754, 9755, 9760]
                          VipMonitor   UP       [464, 10936, 10940, 10941, 10942, 10966]
                            Stargate   UP       [9773, 9819, 9820, 9837, 9842]
                InsightsDataTransfer   UP       [10050, 10173, 10174, 10181, 10184, 10185, 10186, 10187, 10188]
                               Ergon   UP       [10178, 10309, 10310, 12813, 12820]
                             GoErgon   UP       [10267, 10371, 10372, 27241]
                             Cerebro   UP       [10342, 10477, 10478, 10700]
                             Chronos   UP       [10443, 10566, 10567, 10585]
                             Curator   UP       [10575, 10695, 10696, 10944]
                               Prism   UP       [10698, 11081, 11082, 31477, 31779, 31816]
                                Hera   UP       [10845, 11241, 11242, 11243]
                                 CIM   UP       [11093, 11364, 11365, 11374, 11375]
                        AlertManager   UP       [11316, 11638, 11639, 11695]
                            Arithmos   UP       [11734, 11888, 11889, 11956]
                             Catalog   UP       [12009, 12127, 12128, 31352, 31402]
                           Acropolis   UP       [8483, 12293, 12436, 12437]
                               Uhura   UP       [12455, 12692, 12693, 13371]
                   NutanixGuestTools   UP       [12734, 13057, 13058, 13065, 13102]
                          MinervaCVM   UP       [13865, 14025, 14026, 27263, 27337]
                       ClusterConfig   UP       [13986, 14478, 14479, 14480, 14504]
                         APLOSEngine   UP       [14267, 14622, 14623, 14624]
                               APLOS   UP       [15094, 15240, 15241, 15242]
                     PlacementSolver   UP       [15228, 15687, 15688, 15689, 15735]
                               Lazan   UP       [15331, 15859, 15860, 31416]
                             Polaris   UP       [15633, 15948, 15949, 15976]
                              Delphi   UP       [15811, 16055, 16056, 16057, 16077]
                            Security   UP       [16007, 16230, 16231, 16232]
                                Flow   UP       [16124, 16386, 16387, 16388, 16398]
                             Anduril   UP       [16330, 16493, 16494, 16495, 16504]
                               XTrim   UP       [16406, 16589, 16590, 16594]
                       ClusterHealth   UP       [8449, 8450, 16545, 16749, 17182, 17183, 17186, 17188, 17281, 17282, 17289, 17290, 17291, 17297, 17298, 17301, 17302, 17303, 17304, 17305, 17306, 17307, 17423, 17424, 17541, 17542, 17543, 17544, 17549, 17550, 20423, 20424, 20425, 20426, 20427, 20431, 20432, 20433, 20435, 20441, 20447, 20451, 20628, 20631]
2024-05-30 07:17:12,641Z INFO MainThread cluster:3104 Success!
Kcmount
Forum|alt.badge.img+7
  • 367 replies
  • May 30, 2024
Morning,
How much RAM does the CVM have allocated to it?
Can you see anything in ~/data/logs (if you use ls -lrt to sort by date and look for the most recent)
  • May 30, 2024
