hello i hope everyone doing well am trying to install Nutanix community on VMware i follow the same steps in documentation of my friend Jeroen Tielen but when i try to run cluster with commande cluster start command enter in loop but the services remain in down what i can do to resolve this problems
this this state of cluster all service are down here when i try to start cluster i get this message cluster down cluster start command enter in loop but the services remain in down
Best answer by ktelep
You need to type “thisisunsafe” after clicking in the middle of that window, or use Firefox.
So it looks like the cluster is started. The cluster start commando is showing all services which need to start. Just wait until all are started. Then for the last screesshot you posted. Read this post: https://www.jeroentielen.nl/no-it-is-not-nutanix/
