No more CVM after disk remove | Nutanix Community
  • April 29, 2024
  • 110 views
Hello team,
Always in learning Nutanix that’s totally new for me, I performed some tests today.
One of those was to remove a disk to check if system will still be up. And… no :)
All the CVM is crashed because it don’t find the removed disk.
I have a Nutanix CE with a single node cluster.
Is Nutanix storage pool not working as a RAID (1 or 5?) by default? Is there something to configure?
Coming from VMWare, I make the comparison. On my ESXi I can lost one disk as I’m protected by the RAID-5 of the Raid-controller. Should I also use a RAID-5 for Nutanix? I read that disk must be in RAID-0 and Nutanix will protect it.
How protect my single node cluster from a single disk failure?
I certainly misunderstand or misconfigure something.
Thanks for you help !
PS: The disk I removed was not one of those declared for the CVM during the installation, it’s a “Data” disk.
Best answer by JeroenTielen
A single node cluster is, off course, not protected for disk outage. Unless you have multiple data and multiple cvm disks in it.
The normal, commercial, version of nutanix has a requirement of 3 nodes minimum to handle outages. And it can only run on specific hardware which is on the HCL.
  • 1349 replies
  • April 29, 2024
