Get efficiency state for VMs using API | Nutanix Community
  • April 18, 2024
  • 179 views
Ahmed_Elyacoubi
Is there a way to fetch the efficiency state for VMs (Bully, Over Provisioned, Constrained, Inactive VM, Good) using API requests?"
Best answer by Ahmed_Elyacoubi
this works:
get https://pc_ip:9440/api/nutanix/v3/groups
body:
    "entity_type": "mh_vm",
    "query_name": "eb:data:Efficiency-1713467304436",
    "grouping_attribute": " ",
    "group_count": 3,
    "group_offset": 0,
    "group_member_count": 120,
    "group_member_sort_attribute": "vm_name",
    "group_member_sort_order": "ASCENDING",
    "group_member_attributes": [
            "attribute": "vm_name"
            "attribute": "capacity.vm_efficiency_status"
    "filter_criteria": "(platform_type!=aws,platform_type==[no_val]);is_cvm==0;feature_name==VM_INEFFICIENCY_DETECTION"
  • Trendsetter
  • 43 replies
  • April 19, 2024
Didn’t find anything, the closest information we could retrieve is using this API call https://www.nutanix.dev/api_reference/apis/prism_v3.html#tag/vms/paths/~1vms~1list/post
Ahmed_Elyacoubi
this works:
body:
    "group_count": 3,
    "group_offset": 0,
