Nutanix CE + Microservices | Nutanix Community
  • April 11, 2024
  • 8 replies
  • 180 views
Does Nutainix SE support deploy Microservices?
P.S. I was trying 10+ times to deploy but every time get error.
ktelep
  • 540 replies
  • April 11, 2024
What error do you get when you’re deploying and what process are you following for the deployment.
I have NKE deployed on one of my CE clusters now, so it does work.
  • April 11, 2024
{"ClusterName":"prism-central","ClusterUUID":"376d5a9e-6a30-41f2-69db-26aafe2b1467","ClusterDescription":"","DepPercent":100,"DepStatus":5,"DepMsg":"Failed to deploy base service: Max retries done","MasterIPs":["192.168.5.2"],"EtcdIPs":["192.168.5.2"],"WorkerIPs":["192.168.5.2"],"EnvoyIPs":["192.168.5.2"],"ExternalMasterIP":"192.168.5
.2","MspDNSIP":"10.100.7.41","Domain":"prism-central.nutanix.local","LockDownStatus":false,"ControllerVersion":"2.4.2.2"}
bcaballero
  • Guardian
  • 186 replies
  • April 11, 2024
Hi @ZAnton
I’ve deployed successfully Microservices Infrastructure with CE. Don’t know if it’s “officially” supported but it works.
I was getting errors with PC 2022.6.0.10 but afterwards tried with PC 2022.6.0.9 and it worked.
Hope this helps
Regards!
Forum|alt.badge.img+7
I had a lot of issues deploying NKE after enabling microservices.
Problems in a CE2 cluster and licensed prod cluster as well.
Tried different versions of NKE in CE2 as well, but couldn't get it working.
The switch to microservices has been brutal, but I think overall it is a step in the right direction.
  • April 11, 2024
bcaballero wrote:
Hi @ZAnton
Hope this helps
Regards!
I was try but get same error ((
bcaballero
  • Guardian
  • 186 replies
  • April 12, 2024
HI @ZAnton
Sorry to hear that ☹️
Have you configured iSCSI Data Services IP on the cluster?
When deploying MSP can you see any Volume Group creation intent on cluster tasks?
Does your PC have internet connection?
Hope this helps
Regards!
  • April 12, 2024
bcaballero wrote:
HI @ZAnton
Hope this helps
Regards!
Yes, IP configured. Cluster have Internet access. Today I was re-install cluster from scratch but get same error. No info. No error description. After failure I need redeploy PC because activate Microservices Button not active any more. I lost 2 weeks for trying deploy Nutanix.
  • April 14, 2024
Problem resolved!
I re-read the documentation again and saw that network 10.100.0.0/16 is reserved.
Thanks for help!
