Benifits with choosing Nutanix rather than vmware | Nutanix Community
what are we getting from nutanix rather than using vmware.
I have few questions.
  1. how’s the license scheme in nutanix.
  2. what are the backups & recovery methods in nutanix.
  3. what type of softwares & products that supports with nutanix vm backup process. as an example in vmware backups. *Synology vmware backup * Qnap vmware backup * Veeam vmware backup & replication * Comvault vmbackup *Acronis vmware backup.
  4. How replication work in nutanix
  5. How High Availability feature work in nutanix.
  6. How vm Live/PowerdOff Migration work in nutanix
  7. what mechanism is use in nutanix while comparing to vmware vMotion
  8. what type of converters are use in nutanix. Ex: vCenter Converter in vmware
  9. what is the snapshot mechanism in nutanix.
Thank You.
Hello @KasunChathuranga
Please check my replies on yellow
    1. For HCI, it’s based on number of cores, and AHV is included, doesn’t have separate license
    1. Backup and recovery is based on Snapshot local or replicate to remote site or both, Async, Near Sync, or Sync. for more information: https://www.nutanixbible.com/4e-book-of-aos-backup-dr.ht
    1. If you are using Nutanix with ESXi, then it will use VMware support products, if you are using AHV, most of backup software support agentless backup for Nutanix AHV, for example, Veeam, Commvault, Veritas, HYCU, and more.
    1. Based on Snapshot replication, for more information: https://www.nutanixbible.com/4e-book-of-aos-backup-dr.html
    1. check this: https://www.nutanixbible.com/5b-book-of-ahv-how-it-works.html#vm-high-availability-ha
    1. check this https://www.nutanixbible.com/5a-book-of-ahv-architecture.html#live-migrations
    1. https://www.nutanixbible.com/5a-book-of-ahv-architecture.html#live-migrations
    1. Nutanix Move
    1. https://www.nutanixbible.com/4c-book-of-aos-storage.html#snapshots-and-clones
Thank You.
ktelep
  • 538 replies
  • April 1, 2024
I think you’re best bet would be to read through the nutanixbible.com to get a deep dive into the questions here and also reach out to a Partner or Nutanix SE that can spend the time to walk through all of these in detail for you.
Thanks for replying ktelep,
i ll refer the bible as you said. but sorry to say there are no nutanix partners in my country -Sri Lanka-. best thing is readout bible first. i ll check.
Thanks for your support
Moustafa Hindawi
    1. Nutanix Move
Thank You.
