Nutanix File Server Vlans | Nutanix Community
Hi Anyone help me on below quarry,
I am little confession while deploying the File Server i have seen two options are one is client network and storage network.
for client network we are taking  new three ips in the the client ip range
and for storage network we are taking Four ips which are the new ip in the cvm range
here …?
which vlans should use for client network..?
which vlans should use for storage network..?
it would be appreciated if someone explain this as soon as possible.
  • March 15, 2024
Hello there,
For the clieint network, can be any vlan (other than the cvm vlan), just recommend to get your clients routed with the fewest hops possible.
For the storage network, its recommended to put this on the same vlan as the cvms in order to avoid network bottlenecks.
qamarabbas
  • 117 replies
  • March 16, 2024
Storage Subnet will be in the range of CVM VLAN where as Client subnet could be your server/ client vlan to access the SMB / NFS Share.
Note:  You cann’t access the share if you are on same VLAN of Storage.
