Nutanix AOS_ESXi installation getting failed through Foundation | Nutanix Community
  • February 15, 2024
  • 370 views
I'm trying to install “AOS+ESXi” on Dell XC6320 Node, through Foundation VM. but installation is getting failed with below errors.
Exception: This node is expected to have exactly 1 HBA with pci id 9005:028f. But phoenix could not find any such device
2024-02-12 10:43:42,845Z ERROR Exception in running <ImagingStepRAIDCheckPhoenix(<NodeConfig @bcd0>) @b8b0>
  File "foundation/imaging_step.py", line 160, in _run
  File "foundation/imaging_step_misc_hw_checks.py", line 154, in run
Exception: Couldn't find hardware_config.json
DEBUG Setting state of <ImagingStepRAIDCheckPhoenix(<NodeConfig @bcd0>) @b8b0> from RUNNING to FAILED
DEBUG Setting state of <InstallHypervisorESX(<NodeConfig() @bcd0>) @b4c0> from PENDING to NR
WARNING Skipping <InstallHypervisorESX(<NodeConfig() @bcd0>) @b4c0> because dependencies not met
Moustafa Hindawi
Please reach out to Nutanix support
  • February 28, 2024
Hi insanwin,
did you update the firmware prior to foundation, can you see if the hardware is present and funtioning from the iDRAC? if the pre-requisites are not met the foundation will fail…
Best Regards
John
