add additional hdd | Nutanix Community
add additional hdd
  • February 14, 2024
  • 142 views
Hi All,
I have deployed one node cluster and it is running well.
I would like to additional HDD of 500GB
I added the 500 GB drive on the AHV node however how do I add it on the console
any suggestion… thanks
  • 1372 replies
  • February 15, 2024
Are you running community edition? Or is this a production '1 node’ cluster? (Running ROBO)
I assume you would see the disk in the hardware dashboard in prism element. Then you can add the disk. If you dont see it you have to do it manually via disk_operator.
I am running community edition
1 node cluster
Can you please share a document that I can follow for the same
