Is there a feature within the Nutanix Sizer that allows for manual adjustment of the vCPU to pCPU ratio? If so, could someone guide me through the process or point me to the relevant documentation or resources?
Nutanix Sizer vCPU to pCPU ratio
Best answer by BartDonders
Hi, yes, it i spossible to change this for all workloads, or some workloads…
Select multiple workloads and select Bulk change → Edit workloads.
Adfter selecting that, scroll down to the Workload Specific Inputs and change the ratio.
Bart
