LCM framework starting | Nutanix Community
  • January 25, 2024
  • 277 views
I downloaded and installed Nutanix CE single-node in a VM and need to test Nutanix Files for that I downloaded File Server, but when I go create FS it tells me:
File Server software downloaded
Version 4.4.0.1 downloaded. To proceed with install, an update of File Server Manager(FSM) is required through LCM. Go to LCM
If go LCM it get stuck on LCM framework starting…
I need to setup this as soon as possible for a test integration. any help?
  • 1361 replies
  • January 25, 2024
What are your vm specs? And the cvm specs? And what are the specs of the host self?
