I do a AHV convert from VMWare to AHV recently on my 4-node Nutanix NX-1450. Unfortunately only 2 nodes are successfully converted, one node remained failed and retain as ESXi and the other node failed to download the bundle binary.
I wanted to reprovision from scratch using Foundation (Bear Metal Deployment) Tools. I have the Foundation 5.5 however, when provision it cannoy connect to IPMI (Error attached)
so I an suspecting it is not compatible. Any body can help on this. If you have the earlier version of Foundation Tools maybe can help me?
