Nutanix Tool to Optimize VM Utilisation | Nutanix Community
Nutanix environment with 74 nodes and around 2600 VMs It is observed that the VMs are overprovisioned, utilizing only about 30% of the resources. We request that you help us understand whether we have any tools, like vROps, to optimize the performance or recommend downsizing the CPU, memory, and storage.
Best answer by sl.farhanparkar
Hi Divya,
Prism Central Starter edition had feature Resource Inefficiency Detection and Right-sizing, which gives report which can be used to optimize the VM resources.
https://next.nutanix.com/how-it-works-22/behavioral-learning-tools-prism-central-resource-management-38927
This can help you
F>P
  • 1394 replies
  • October 31, 2023
In Prism Central you can get a report with the overprovisioned virtual machines. That you can use to shrink resources.
  • October 31, 2023
Please guide us the assessment that should be taken care prior to shrinking the resources
sl.farhanparkar
Hi Divya,
This can help you
F>P
