EXT4 errors on CVM x.x.x.x. Detected on md2 partition. Assistance needed | Nutanix Community
  • September 28, 2023
  • 552 views
mdsr83
 EXT4 file system errors are detected: Filesystem errors found on CVM x.x.x.x. on the below device(s):  Device: md2, Partition: home, Max Mount Count: -1
Will the restart be a helpful step.
Best answer by JeroenTielen
The best I can say is: Involve support.
  • 1394 replies
mdsr83
  • 8 replies
  • October 1, 2023
Truly respect your answer, unfortunately the support is expired.😌
