Integrate the Nutanix cluster with SolarWinds | Nutanix Community
  • September 21, 2023
  • 403 views
AdelMarei
The Problem
We need to integrate the Nutanix cluster with  SolarWinds  to view the VMs - compatible /supported - data ( VM names, VM IPs,…) in the SolarWinds GUI.
Get the basic VM management actions as per Nutanix document  AOS ( 6.5)
https://www.nutanix.com/partners/technology-alliances/solarwinds
Host and Guest VM availability, fault and performance monitoring and alerting:
    * CPU/Memory/Network statistics
     * Storage statistics
     * Basic VM management actions
supported Nutanix versions
Troubleshooting
•    We have generated a new SSL.
•    We have tried to add the cluster using the Prism Central (PC) , could not login.
Current status
1)    The Nutanix Prism Element (PE) can be seen under the SolarWinds
Environment
Single cluster
Single PC
Other links we have checked
SolarWinds
https://support.solarwinds.com/SuccessCenter/s/global-search/%40uri?language=en_US#q=Nutanix&t=All&sort=relevancy
qamarabbas
  • 117 replies
Whats the error you are getting , just the authentication error or anything else?
AdelMarei
  • 9 replies
  • September 22, 2023
Hi @qamarabbas 🙂,
Regarding the PC attempt , yest it is an authentication problem , and the PC IP(x.x.x.120) was resolved in the SolarWinds GUI as the PE (x.x.x.116) I am checking in to it , the cluster was added using PE IP, still listed;we can see the HW side fans,… from the SolarWinds GUI only for the time being.
