Hello Community,
I want to configure replication and failover plans between 2 separate Nutanix clusters, both running ESXi hypervisor.
I do have Vmware SRM licenses and I am aware of these 2 possibilities :
1. Replicate VMs using Nutanix Protection Domains (either with Async DR or with Metro Availability) and configure Failover scenarios with SRM via Nutanix SRA
2. Replicate VMs using VMware vSphere Replication Appliance and configure Failover scenario with SRM
My question is which of the possibility would you recommend ? which is better in terms of performance and flexibility ?
Thanks.
