Nutanix files command to see who owns share | Nutanix Community
  • August 10, 2023
  • 280 views
from cli whats the command to see which Nutatnix files VM owns a share? i’ve done this before and i cant remember what the command was we’ve had issues with copiers not being able to scan when we use the host name but it works fine with the IP
Best answer by BartDonders
maybe afs share.owner_fsvm
See the  output of my test files instance...
<afs> share.owner_fsvm nfsexport path=/labfiles/nfsexports/logs
Owner NVM Name: NTNX-Files-3
Owner NVM internal IP address: 172.17.0.103
Owner NVM external IP address: 172.19.0.102
Owner NVM UUID: cca58275-7b34-4462-b6f8-f000d5324ee9
Share path: /zroot/shares/cca58275-7b34-4462-b6f8-f000d5324ee9/:d5b13577-6b18-4662-b571-c3f7d3556c15/ddb46789-cc21-4fc6-8608-04795faa57ef/nfsexport/logs
Absolute path on the owner NVM: /labfiles/nfsexports/logs
<afs>
BartDonders
  • Trendsetter
  • 48 replies
  • August 11, 2023
<afs>
