RPO is in days, but falls under the 6 hour RPO check | Nutanix Community
I want to create a configuration in Sizer that takes a snapshot once a day.
However, an error message is displayed on Sizer and configuration is not possible.
"Cluster: 'Cluster-1' nodes with SSD capacity less than 7.68TB are not allowed when configuring Hybrid nodes with RPO of 6 hour and node capacity ranging from >96TB upto 136TB. For more info, refer to Nutanix Maximum Configurations & Snapshot Frequency Field Requirements"
Sizer's workload only has Daily Snapshots set.
"Hourly Snapshot Retained" is unchecked.
However, for some reason, the condition check for 6 hours RPO is caught, and the hardware cannot be configured.
What should I do to remove this error?
  • 32 replies
  • April 27, 2023
Hello Takhagi,
Looks like a bug, I can see that with daily snapshot the hourly RPO are coming into play. Will ask engineering to look into this and provide an ETA.
cc: @Parvinder
Arun
Elroy
  • 9 replies
  • April 28, 2023
Hello Takhagi,
  It should be fixed, you may want to try to create the sizer scenario again. I am now able to get through the error message now.
Best regards
Elroy
  • May 26, 2023
Has this issue been fixed?
I am still reproducing it here.
Moustafa Hindawi
Create a new sizing scenario
