My 3 node cluster consiting of 1065-G5 nodes is coming EOL this year. I will be replacing the hardware with a NX-3360N-G8 cluster. What is the recommended workflow for replacing the hardware? One thing to note is the current cluster is licensed with Prism Pro and the new one will be licensed with Starter as I’m not using all the features in Prism Pro.
Is the replacement as easy as expanding the cluster one node at a time, migrating the workloads and then removing the old cluster? Will there be any hiccups with difference in licensing?
