Node is Down after firmware upgrade - Host X.X.X.X appears to have failed | Nutanix Community
  • February 8, 2023
  • 6 replies
  • 982 views
after a firmware upgrade, one host is locked DOWN in maintenance mode :
CVM: 192.168.131.132 Down
I can run a command to exit maintenance mode but it is not working and it is "Removed from metadata store" :
nutanix@:~$ ncli host edit id=7 enable-maintenance-mode=false
Hypervisor Address : 192.168.131.122
Host Status : NORMAL
Oplog Disk Size : 394 GiB (423,054,278,649 bytes) (3.9%)
Under Maintenance Mode : false (ncli_manual)
Metadata store status : Node is removed from metadata store
So I tried to recover it but the script fails :
nutanix@:~$ python /home/nutanix/cluster/bin/lcm/lcm_node_recovery.py 192.168.131.122
Recovering node 192.168.131.122
Checking if the node 192.168.131.122 is in phoenix
Current node status host Node 192.168.131.122 out of phoenix mode
Bringing host None out of maintenance mode Successfully put host None out of maintenance mode Bringing CVM 192.168.131.122 out of maintenance mode
Traceback (most recent call last): File "/home/nutanix/cluster/bin/lcm/lcm_node_recovery.py", line 255, in <module> if not main(): File "/home/nutanix/cluster/bin/lcm/lcm_node_recovery.py", line 231, in main if not obj.recover_node(): File "/home/nutanix/cluster/bin/lcm/lcm_node_recovery.py", line 195, in recover_node svm_ip=self.svm_ip): File "build/bdist.linux-x86_64/egg/cluster/client/genesis_utils.py", line 2006, in cvm_set_maintenance_mode_status
Any idea ? Thank you by advance!
Best answer by GuiEIVP
I finally managed to get things up. I totally shut down, and disconnected all the Nutanix and the Cisco switch. EVentually the CVM woke up !
Unfortunatly I cannot get it back to the cluster, but will create a new post...
  • 1363 replies
  • February 8, 2023
Just involve support. They are great and will help you.
  • February 8, 2023
Thanks for your fast answer. Yes support is great but, this happens on my previous Nutanix, on which the support ended… a few month ago only.
So I ask a little help from community ;)
Elroy
  • 9 replies
  • February 9, 2023
  Not sure if this would help
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA0600000008ZBnCAM
  However, if you plan to run along without any valid support entitlement, probably I would consider reimage the node at some point if there is not much direction and it needs to bring back up in a timely manner.
  • February 9, 2023
Thanks Elroy,
yes I already tried this fix but it did not work…
I tried to reimage but Phoenix did not want, indicating there is a valid installation.
Is there a way to force this with “phoenix” command lines ? I found no documentation about this this, every doc I have says that I should get on the installer, but I cannot I get on phoenix shell directly.
Elroy
  • 9 replies
  • February 9, 2023
  Did you try with standalone foundation VM?
  • February 14, 2023
