AOS manual upgrade / “pre-upgrade” task | Nutanix Community
  • January 22, 2023
  • 1024 views
 tl;dr how to perform pre-upgrade checks from the command line?
Hello Guys,
I have a question related to the performing manual / cli upgrade (command line). Here’s the scenario:
  • AOS with ESXi as a hypervisor,
  • multiple ROBO offices / Dark Site (no access to the internet),
  • Dark Site server with LCM,
  • very limited broadband: 16Mbit with static shaping (4Mbit) for management purposes and 12Mbit for business
It is very difficult to upload via AOS GUI 4-5GB of  upgrade and .json file. 3-4% / 10minutes and upload task informing about a ‘server issue’. I’m 99% sure that it related to the broadband shaping.
Solution is simple:
  • upload tar.gz install/upgrade bundle,
  • ‘untar’,
  • install ( ./install/bin/cluster -i ./install upgrade )
My question is: is any magic command to start pre-upgrade tasks with is normally presented in GUI if upgrade package is available? It will be very helpfull to start pre-upgrade check in-advance the main upgrade.
I tried to find the command in lab:
-- uploaded the bundle in ‘normal GUI’ way,
-- started pre-upgrade check from GUI
-- ps aux from CVM:
It looks that install/bin folder is keeping script “pre-upgrade”. I tried with different ways run it from the ‘nutanix’ account: /usr/bin/python2.7 -B /home/nutanix/software_uncompressed/nos/6.5.1.6/install/bin/preupgrade
No luck...
Hello @Dominik.Siedlak
LCM Pre-Checks
test_aos_afs_compatibility
Verifies that AOS and Nutanix Files are compatible.
test_cluster_status
Verifies that the cluster statuscommand returns a healthy state.
test_cassandra_status
Checks zeus_config_proto (run zeus_config_printer for equivalent) for the following:
  • Node cassandra_status is not Normal.
  • No nodes are in maintenance.
  • The NCC check described in KB 4301 returns a PASS.
test_nutanix_partition_space
Checks that all CVMs have sufficient space on /home/nutanix.
test_network
Verifies that CVM IPs are reachable.
test_hypervisor_tests
Verifies that SSH can connect to the hypervisor.
  • AHV: verifies libvirtd on AHV hosts.
  • ESXi: checks if there is a VmkNic for all ESXi hosts in the same subnet as eth0/eth2. Verifies pyVim connectivity to ESXi hypervisor.
test_zk_status
Verifies that at least three zk hosts are available, on a cluster having three or more nodes.
test_replication_factor
Verifies that no containers in the cluster have RF=1.
test_under_replication
Checks for under-replication in the cluster.
test_prism_central_prism_element_compatibility
Checks that the registered Prism Central is compatible with Prism Element by reading prism_central_compatibility.json.
test_prism_central_ova_compatibility
Checks that Prism Central has boot and data partitions on different disks.
test_degraded_node
Verifies that no nodes are degraded.
test_vlan_detection
Verifies that LCM can fetch VLAN information from all nodes using NodeManager.
test_upgrade_in_progress
Checks to see if a non-LCM upgrade is in progress.
test_foundation_service_status_in_cluster
Checks to see if the Foundation service is running on any node in the cluster.
test_vmotion_support/test_live_migration_support
Checks that an ESXi or Hyper-V host has vMotion enabled.
test_cluster_config
Verifies that the cluster has vSphere HA enabled on vCenter mapped to a Nutanix cluster. (Make sure that you disable admission control.)
test_hosts_managed_by_same_mgmt_server
Verifies that the same management server (vCenter) manages all hosts.
test_hypervisor_config
  • All hosts: verifies that the host has sufficient space.
  • ESXi:
    • Verifies that the host does not have APD/VMCP enabled. (If yes, disable it.)
    • Verifies that no CD-ROMs (ISO image stored in local storage) or other physical devices are attached to the VM. (If yes, remove the physical device from UVM.)
  • AHV: verifies that the host can enter maintenance mode.
  • Hyper-V: none.
test_check_revoke_shutdown_token
Checks that the CVM can revoke the shutdown token after an LCM update completes on a node in a cluster.
test_ntp_server_reachability
Checks that the configured NTP servers are reachable before starting LCM updates.
test_prism_central_minimum_resource_check
Check that Prism Central is configured with the correct license and has enough memory to support all licensed features.
test_two_node_cluster_checks
Check that the configuration on a two-node cluster allows LCM updates.
  • Check that both nodes are up and the cluster is functional.
  • Check that the cluster has selected an LCM leader.
  • Check that the cluster has configured a witness VM.
  • Check that there are at least two meta disks available on each CVM.
test_zk_migration
Check to see if there is a Zookeeper migration in progress.
test_catalog_workflows
Check that the most commonly used catalog workflows for LCM are currently performable.
test_foundation_workflows
Check whether the current version of Foundation on the cluster is on the LCM denylist.
test_uniform_foundation_across_cluster
Check to make sure that every node in the cluster is running the same version of Foundation.
test_esxi_bootbank_space
Check that the ESXi bootbank has enough space for LCM upgrades that involve restarting into Phoenix.
test_esx_entering_mm_pinned_vms
Check to see if any node in the cluster contains a VM that cannot be live migrated to another node.
Note: For inventory scans, LCM skips the aos_afs_compatibility and under_replication tests, because inventory scans are not disruptive.
Moustafa Hindawi
LCM Pre-Checks
test_cluster_status
test_network
test_zk_status
test_degraded_node
test_vlan_detection
test_cluster_config
  • ESXi:
  • Hyper-V: none.
test_zk_migration
Hi Moustafa,
Thank you for answering me in such a short time :-) I am asking about a pre-checks related to the new release of the AOS and upgrade. I’ve downloaded upgrade package tar xzf to it with is keeping installer in the ‘install’ folder.
Install is very simple: start the command: “./install/bin/cluster -i ./install upgrade”
Process will start pre-check and if all is fine upgrade.
I  am asking how to start ‘Pre-upgrade’ from the command line instead of from GUI.
Command-line way of installation: it is showing progress in CLI and in GUI including health checks related to the upgrade:
I am asking if is any single command to process in-advance  pre-checks with no installation. Thanks!
Dominik
Moustafa Hindawi
All the above commands used before upgrade or update, if you want only to check the compatibility then refer to compatibility matrix as below, also you need to check the hardware itself and Hypervisor version supported or not
