NC2 on Azure , Add Cloud account | Nutanix Community
Hello Everyone,
I am trying to deploy NC2 on azure but , I need to Add cloud account .
Everytime I gave all the correct information of azure like, Directory ID , Subscription ID, Application ID, and secret value it gave error “Azure credentials are not valid.” How to resolve it .Please Help.
Best Regards ,
Rajesh Kumar
dlink7
Forum|alt.badge.img+19
  • Moderator
  • 107 replies
  • January 4, 2023
Hi Rajesh
Did you allow the listing from Microsoft? https://portal.nutanix.com/page/documents/details?targetId=Nutanix-Cloud-Clusters-Azure:nc2-clusters-azure-allowlist.html
Are you able to provide any Azure logs?
dlink7
  • Moderator
  • 107 replies
  • January 4, 2023
Double check your using the key value instead of the secret key id
Also do you have app contributor access?
dlink7
  • Moderator
  • 107 replies
  • January 6, 2023
try running this Register-AzResourceProvider -ProviderNamespace Microsoft.Compute
or at least check for the provider being enabled
