Nutanix Files License | Nutanix Community
I need Nutanix Files licence please tell me the procedure.
Moustafa Hindawi
Hello @Rajeshkumar1504
How many used capacity will be used in TiB?
@Moustafa Hindawi I need starter licence only.
  • 1361 replies
  • December 20, 2022
Just install it with MAX 1TiB size and you are good to go.
@JeroenTielen  I am not able to install it as I don’t have access to support portal to download it. Now guide me on that please.
Moustafa Hindawi
Files needs PRO license, Start licenses for Nutanix Objects only.
However, your NCI or AOS license includes free Files license for 1 TiB. To add more your NCI or AOS has to be PRO license first.
@Moustafa Hindawi  Sorry for inconvenience but I don’t have any licence right now I just Downloaded and install nutanix community edition but Now I wanna use Nutanix Files .Please tell me how to do that.
Moustafa Hindawi
As @JeroenTielen said, deploy Files with 1 TiB , I am not sure it will be free on community edition or not.
  • 1361 replies
  • December 20, 2022
Well you can use it on you community edition. There is a download in the “upgrade software” section. But you cluster needs to have access to the internet.
@JeroenTielen Can you please tell me , How can i give my cluster access to the internet.?
  • 1361 replies
  • December 26, 2022
Make sure the dns and gateway is configured correctly. Although if you are running an older version of ce you will not see the download option.
  • 13 replies
  • December 28, 2022
if yoy want to use space lower than 1TB, No licence is required.
