Azure VM Migration to AHV Cluster | Nutanix Community
  • December 1, 2022
  • 424 views
i wants to Migrate Azure VM to AHV Cluster, please help us to Migration Procedure.
Azure Cloud VM to Nutanix AHV Cluster.
Best answer by manfred
Hi Santosh,
you can use Nutanix Move for this:https://portal.nutanix.com/page/documents/details?targetId=Nutanix-Move-v4_6:Nutanix-Move-v4_6
you can download the software from the nutanix support portal.
manfred
Forum|alt.badge.img+7
  • 23 replies
  • December 1, 2022
Hi Santosh,
  • 13 replies
  • December 1, 2022
Try nutanix mOve tool
