Dell XC750-14 install Hyper-V | Nutanix Community
  • November 30, 2022
  • 82 views
Elroy
Hi All,
  We have an issue trying to install Hyper-V on Dell XC750. From what I can find on the document, it should be supported. However, I am not able to find the customised image for Hyper-V. Appreciate if anyone can share thoughts. Thank you
Regards
Elroy
Moustafa Hindawi
Hello @Elroy
Only XC750-14 CORE which supports Hyper-V (Hyper-V 2019 only) starting from AOS 5.20.1.1.
I can’t find Hyper-V Hypervisor JSON for Dell, however contact support to obtain it. and obtaining the Hypervisor binary files from the Hardware vendor's website.
BartDonders
  • Trendsetter
  • 48 replies
  • November 30, 2022
According to the whitelist.json for Foundation, there is nothing like a Dell customised ISO for Hyper-V.
The standard ISO from Miicrosoft doesn’t work?
Bart
