Nx-1065 EOL Use for DEV Env Cannot Upgrade to Latest AOS | Nutanix Community
  • September 27, 2022
  • 9 replies
  • 247 views
apiwat_sang
I have Nutanix NX-1065 and It’s the end of support life. but I need to use it for POC and Dev Envalument. Have nutanix can upgrade to lasted AOS?
Best answer by gabeo
@apiwat_sang
You can definitely do this. At least it works for me on old hardware.
Download the AOS tar.gz and put it on a CVM in a directory you create within /home/nutanix. For example, create /home/nutanix/upgrd, put it in there with WinSCP, or scp. Then SSH to the CVM and do:
$ cd /home/nutanix/upgrd
$ tar xvf nutanix_installer_package-release…..tar.gz
$ /home/nutanix/upgrd/install/bin/cluster --ignore_preupgrade_tests -i /home/nutanix/upgrd/install upgrade
Edit: this might not be right. let me check and get back to you. I have to find the exact command.
  • 1363 replies
Which generation?
apiwat_sang
  • 7 replies
The server Model is NX-1050 not have a generation in information
 "model_string": "NX-1050"
apiwat_sang
  • 7 replies
nutanix@NTNX-14SMXXXXXXX-B-CVM_IPAddr:~$ allssh cat /etc/nutanix/hardware_config.json | grep "model_string"
    "model_string": "NX-1050",
  • 1363 replies
Got it (in your first post you where typing NX-1065).
The NX-1050 is EOL and new versions will not be tested against EOL hardware, so the NX-1050 is removed from the HCL.
But that doesn't mean it cannot work. You can try to install/foundation the cluster with the version you want, probably it will work, though. ;) But there is no support off course and if it doenst work you must refoundation to the latest working version to have a dev/test cluster.
However again, it is dev/test so try ;)
apiwat_sang
  • 7 replies
Apologize for mistake in my first post. Currently the cluster is running with AOS 5.15.7 I will try upgrade to AOS 5.20.x. Thank you for your advise.
  • 1363 replies
According to this post, it should work: NX-1050 Compatibility matrix
qamarabbas
  • 117 replies
  • October 11, 2022
Upgrade will not works as its failed on pre-checks.
You can refoundation with the latest AOS version.
Moustafa Hindawi
EOL hardware is not qualified for new software, it could support critical security updates.
  • 18 replies
  • October 14, 2022
@apiwat_sang
