Alert PE-PC Connection Failure | Nutanix Community
  • August 18, 2022
  • 1334 views
Hello, I have an alert on Nutanix PE-PC Connection Failure Description: The remote {remote_vm_type} {cluster_ip} is unreachable. I would like some support to correct this alert. Thanks in advance.
@Welton kindly refer to KB-6970 to resolve PE-PC Connection Failure alerts seen in the cluster
  • 48 replies
  • August 19, 2022
