I would like to create a new scenario with Lenovo HW or modify one with NX HW to Lenovo but I don’t how I could that. Anyone could tell me if is it possible?
Nutanix Sizing with Lenovo Hardware
Best answer by StuB
Hey! In Sizer 6.0 you can switch between hardware vendors on an existing scenario in the Cluster settings - access by clicking “Modify” on either the Workloads or Solution pages:
Then select your vendor from the dropdown:
If you are creating a brand new scenario from scratch you will automatically get these cluster settings after creating your first workload, so just select the vendor you want at that point.
