AD User-A Permission Denied To Clone User-B or admin VM Via REST API V3 | Nutanix Community
  • June 17, 2022
  • 81 views
@AnishWalia20 ,
As per previous query, there was no update for clone permission,
But now , on current version of PC 2021.9.0.2 , clone permission is there for ad user, but my query here is to clone  other user’s vm or admin  created vm. This task i am executing via REST API V3 as per previous query.
There is project A(having multiple users) with allow collaboration option, in which ,As a user-A,I am able to clone a vm created by user-B ,
But cloned vm owner property is same as User-B.
I want to change owner property also while cloning vm via api.
After cloning, vm should be owned by user-A.
Please let mr know if there is some method to do so.
Best answer by Balram
Question Update: AD User-A same owner property To Clone User-B  VM Via REST API V3
  • 9 replies
  • June 18, 2022
