Hypervisor Boot Drive Compatibility List | Nutanix Community
  • May 3, 2022
  • 311 views
I want to ask about replaced hypervisor drive. Here is the machine Nutniax Node : NX-1065-G6 Default Hypervisor Boot Drive : Micron 5100 MMTFDDAV240TBC New Hypervisor Boot Drive : SSD WD Green 240GB 3D NAND M.2 SATA 2280 Question : is it compatible and working properly if the default replaced with new hypervisor boot drive ? Reference : Node Naming (NX-1065-G6). Only give information 2 x M.2 Device 240GB.
Best answer by rohan.saksena-55595
Hello @Gusti Emas
SSD WD Green 240GB 3D NAND M.2 SATA 2280 is NOT COMPATIBLE with any NX system including NX-1065-G6. Only M.2 sold by Nutanix are qualified for operation in our appliances (Micron and Intel, specific manufacturing part numbers). Nutanix does not use Western Digital M.2.
rohan.saksena-55595
Hello @Gusti Emas
