Export AHV VM in OVA format | Nutanix Community
I read that we can able to export the AHV VM in OVA format via Prism central GUI if we have both AOS and Prism central supported version. I need to know is there any way to do the same via PRISM CLI. If so,please share me any link for that. Thanks.
-JAI
Best answer by MWStu
I believe the only way to export as OVA is using Prism Central GUI.  I have not seen a way to do it using aCLI
https://portal.nutanix.com/page/documents/details?targetId=Prism-Central-Guide-Prism-v5_19:mul-vm-export-as-ova-pc-t.html
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA03200000098T7CAI
Or alternatively you can download the VM using WinSCP which might be useful if you moving the VM to another cluster with same hypervisor.   For cross hypervisor migrations you can use Nutanix Move
https://next.nutanix.com/server-virtualization-27/ahv-vdisk-part-2-accessing-and-downloading-vdisks-33672
MWStu
  • 10 replies
  • March 25, 2022
  • Trendsetter
  • 44 replies
  • March 25, 2022
HI,
      Thanks for your udpate.
-JAI
